fuel range
rbm33
im wondering what some of you are experiencing on your fuel range.
i have a 2011 300 six days and im getting right at 40 miles per tank, thats on a single track running a pretty good pace. our race season is about to start up and im just trying to figure out if im going to need to schedule a fuel stop or not.
I had to go to reserve at around 41.5 in a race yesterday, so I am guessing 43-44 miles tops on my 2011 250 Six Days in race conditions. I haven't changed the jetting from stock, just lowered the needle.
Install a needle with a fatter initial/root diameter will help you consume less fuel.
I went from the F diameter as in the stock N1E"F" to an H diameter. I run an NOZH top clip with a 42 pilot in my '10 300.
I get much better mileage out of it, both in tight and open trails. Since there is no accelerator pump to waste fuel like on a 4 stroke, the needle diamter plays a large role in how much fuel passes that portion of the needle when you are in the lower throttle ranges.
I used 6 liters yesterday to go about 32 miles at trail ride pace in tight single track. Stock needle 2nd slot 40 pilot 172 main. spent a lot of time in 2nd below 1/2 throttle. I have a 38 pilot coming, maybe I'll look into the nozh ....... 11 250 6 days
2010 300
38, N3CH #2, 175 and float level adjusted.
70 miles on a stock tank. However I ride mostly 2nd gear tight stuff and I am not super aggressive with the throttle
42 N3EW#2 175/178. Lugs well. Punches hard in the mid range. Rips top!
Todays consumption 5L for 60KM. Generally I get around 10KM/L though so as above. Around 100km from the tank.
thanks for the input, i am surprised at the differences in ranges that everyone is experiencing. most of the races that we do here are around the 40 mile range, so maybe with a few little mods and focusing on riding smooth and not wasting a lot of fuel maybe i can make it without a fuel stop.
one more question.... has anyone tested to see far they can run on reserve???
thanks again for the input
Or........how far did you have to push your bike after you learned the hard-way how long it takes to use up the reserve. :)
lol, thats exactly what im afraid of!! i have heard that the reserve fuel range isnt but a mile or so
Working on the same 10KM/L you should get around 5km limping around on reserve. Not much at all. I usually carry another litre of fuel in a bottle in my backpack.
I did notice that richening the needle only a clip position even has a pretty significant impact on fuel consumption.
