Had this 99 ec 200 sittin on a stand in the shop for a couple years now.She was pretty clapped out and the engine was locked up.I was trying to make my life easy and buy another complete bike before opening before opening what I knew was gonna be pandoras box.After a year of browsing craigslist and running wanted ads the extra parts bike couldn't be had.So last night I decided it was tup ime to open her up.Couple things I noticed right off the bat when I took her off the stand and rolled her over to our gearshef to work on was what a tank this thing was.Im gettin older too but I'm not kidding Id hate yo have to push this thing outta the woods.Its my first Gasser tear down,one thing I noticed right off the bat was the bike really doesn't come apart that easy.I can tear my old 87 cr 250 down and have the engine out and sitting on the bench in about 15 minutes.Not the Gasser.Once I got all the plastics off,the subframe and pipe which took awhile,I went after the engine.The shifter is a pain.I went after the barrel and ran into another huge pain in the ass.Broke the bolt that holds the water pump actuater arm on the power valve.Snap.Cheesy easy fix to beef it up.The huge obstacle was the barrel nut in that corner was put on how?Ground started gr!inding down on one of my old favorite half inch wrenches until ultimately there was nothing left.Never got a wrench on it and went after it with a center punch.That worked,no clue yet how a new nut is goin back on yet.Slid the barrel off,its a tight fit but with the piston all the way down I got her.Barrel looked great,piston looked almost new lots of rust stain on the rod.Water had gotten in tbrough a crack in the carb connection and that that.Next step engine removal.Another huge pain.Swing arm bolt was a little stubborn I expected that.Got that out eventually and removed the other engine mounting bolts.Next F**kshow,the engine is a monster and is built with no room to spare.It literally is formed around the front mount and the swing arm.So can't tilt it up and out or lift it from the back and out.Just halfway out wedged and stuck sliding off the stand time of my life.Regrouped after my wtf now moment and pulled the upper shock bolt to get the upper shock out of the frame and get some play in the swing arm.Used a pry bar and worked it out.The engine is heavy,ridiculously heavy.Which I like.I woulda thrown this bike in the dumpster hours before if I hadn't been so impressed with how beefy the engine was built.Got the thing on the bench crank and rod frozen solid.Dumped the engine upside down in a bucket and even after 2 yrar in the shop gunk and water poured out.Heated a quart of marvel mystery oil up nice and hit almost boiling dumped her in there and let her sit awhile.After about half an hour dumped a can of coca cola in on top and went to work on her and got her freed up.But of course not good news.So where from here.The bike has some real funky features like the tack welded wire carriers and the like.But this engine is impressively built so I'm gonna see it through.
