Had a problem with my ec 300 where it started revving as if it was getting air and then got very loud as if it had a hole in the exhaust and found I had to put half a litre of water in it after riding in tight woods where it would have got warm. I found it had loosened the exhaust manifold and wen I removed the expansion pipe there was water in it and found this in at the power valves.
[URL=http://s1100.photobucket.com/user/andyblack7/media/Snapbucket/8E2D0665-orig_zpscb50d8cf.jpg.html]
[/URL]
Is this normal the oil is like a yellow milky colour i run it on castrol 747. The water in the expansion pipe may have came from washing it as it was only started for a second after washing.
[/URL]Is this normal the oil is like a yellow milky colour i run it on castrol 747. The water in the expansion pipe may have came from washing it as it was only started for a second after washing.
