Gas Gas Cylinder / Ports
Jakobi
I'm yet to inspect the cylinder on my gasser but from those with experience, whats the quality of the casting like? Are there many dags? Is there much to be gained by some light sanding on the intakes, and a polish on the exhaust?
Considering giving everything a clean up while the bike is down for its top end but would like to get an idea before I make a start.
Regarding the exhaust side. How much effort is involved in removing the power valve assembly? I assume it would be best to take the valve out before doing this work, or could it be done while in place?
Mine had some serious cast flash in the transfers. like really bad. I mirror finished my exhaust port as i hate carbon buildup.
Also the jug/case matching was horrid. looks liek someone went in there with a dremel and just murdered it. Lots of cleanup on mine. Lots of power differences as well after cleanup.
Is it best to pull the entire power valve out and shine it up too? Is there much involved in removing it?
Looks like I could spend the best part of a day prepping the cylinder
transfer ports really can use some work usually.. i knife edge mine, and polish them smooth. and match intake to reed cage, and smooth exhaust.
I see I see.. This will be my first time in the engine and as such don't want to bite off more than I can chew.. aka farrrk something up :D
I have a dremel and a few different grades of wet and dry to use so will probably just inspect for a start and see how things look.
just don't adjust the port sizes in the cylinder wall, the nikasil can flake. the transfer ports, intake and exhaust are very easy to work - i use a die grinder and a wet dry vac for the mess. matching the cylinder ports to the cases and reed block will have a noticeable effect.
Not looking to widen any ports that I don't have to. Just clean up dags etc.
Whats the best method to match ports as you describe? How would you mark out the material to remove? I'm not looking at pulling the reed block for this top end.
Case/cylinder matching is easy free power.
for the case to cylinder matching use your gasket as a template. grind the case/cylinder with a dremel/die grinder to match. what you want is smooth flow from bottom to top. no edges that interrupt flow.
you will see the transfer ports on the bottom of the cylinder have a divider, it is square edged/flat where it goes into the case. that square edge slows/causes turbulence of the mix. you want to make it smooth/blended and knife edged.
the exhaust port can be matched to the exhaust flange. the only polished surface you really need is the exhaust port. it stops carbon build up.
i gotta say this before you go crazy with your die grinder. stay away from the nikasil. it will flake. do not open ports in the cylinder itself.
you can really mess things up if you are not careful. that being said, if you do sensible grinding, you'll see an improvement. it is free power. it really helped my 200 motor. when i swapped the 300 in, i was in too much of a hurry to do the porting. over the winter i'll go through it pretty extensively.
there's vids on youtube.
here's a good one on the transfer ports. in fact i've only just skimmed this guys stuff, but it doesn't look like he's a hack..
http://www.youtube.com/watch?v=kKQ95VnP2bE at 5:45 he starts to knife edge the transfer split
for case matching, go about :30 seconds into this video to see.
http://www.youtube.com/watch?v=kFbMn8flLhk&feature=related
Ken is def not a hack and very well respected in the north east as well as denny at flotek from va
good to know - you never know on a diy video if it's someone who knows what they're doing, or a hack. i didn't have a chance to look at all his vids to see if his methods are sound, but his transfer port stuff looks good. dremel is the slow and tedious way for sure though.
Well, you seal off the cases around the con-rod using duct tape.
You then want to determine what areas of the cylinder and cases you want to grind on.
Take a light grease impression from both the surfaces using a spare new gasket placed between the jug and casing. You can repeat this again.
If you just remove from one side you may end up with too thin of a mating surface in the end. D'oh!
Now grab a Dremel and grind baby grind. Use a metal barrel type bit.
Mine had lots of ledge to remove.
Lastly, trim the gasket to match as well.
Thanks lads.
I just cleaned up the dags and gave the exhaust port a polish and matched the edges a bit better on the exh flange this time around. Next time I tear it down I will go into things with more detail. It'll help knowing more about how everything works!
I'm still betting you'll need a new rear fender on order after the new top end, and S3 head. :D:D:D
Did you buy the GasGas stock piston or did you get a Wossner, ProX, or Wiseco replacement? The only reason I ask is because the piston crown may be shaped differently changing the squish clearance.
If you watch his earlier videos he explains he uses a dremel because that's what most people have access to. He also goes on to state for noobs its better as its not gonna take off as much material as a air grinder.
Its happier lifting the front end under power now :) Don't wish bad things on me Bailey. I have a finger on the clutch 110% of the time! I went with the Wossner kit. Piston looked very similar to the naked eye.
