gas gas ec 200 crank
chinesegav
hi there
i am just wondering if the crank in a 05 ec200 is used in anyother bike as i can get full crank kits fairly cheep but they dont list gas gas i know the con rod is a honda cr250 item just wonder if any one can shed light on it as if its the honda item im quids in
hi there
a complete crank with the rod for the ec200, where can you find this?
just in case i might ever need one for mine :p
The 200 seems to have used quite a variety of cranks. I'm aware of one with flywheel side roller, one with ball bearing, one has a nut on the drive side, and another has a bolt, and I've got a feeling there was one with a circlip or something weird. And there seems to be some confusion amongst the parts suppliers as to which year has what, although it wouldn't be surprising if the crank is a crossover part because the 200 is manufactured in smaller numbers than the 250/300, so it would make sense to use one.
All GG cranks are unique, but the rod kit for all three (200/250/300) is the same as a Honda CR250. The 200 has used the same crank, and same ignition side ball bearing. Any variation is not standard.
Glenn, Is this for all year ranges? Thanks
From '99 to current, 250/300 for sure. Cranks the same design, bearing journal/press fits/and bearings have changed over the years. I believe the 200s have been the same as well but no personal experience owning different years like my 250s.
