My friend Kirk just picked up a 2011 200 six days just before the Sumter national. He ran out of gas at 16 miles and I had to listen to him the entire ride home to PA. I adjusted the float level and leaned it out to a 42 (from 48) pilot and lowered the needle (raised the clip) one position. Afterwards we tested the mileage around my enduro loop and it was about 12 MPG, not bad for my tight loop but with the small tank (2.4 gallon) this would make +30 mile enduro loops marginal. The plug looked light brown with the new jetting.
I purchased him a 3.3 Gallon IMS tank and installed it last night. The fit was ok but not great and it really takes away from the "thinness" of the stock Gas Gas ergo's. I typically don't like oversize tanks but it's better that listening to Kirk for another 10 hours after the next national in SC.
Upon putting the stock petcock in the IMS tank I discovered that the petcock filter is bypassed with a tube that allows for the reserve. I suspect based on this that the orginal problem in Sumter was from a piece of tank debris getting stuck in the float valve. I pulled the tube out of the filter and plugged the hole (6mm bolt) so the tank will completely empty when the gas is "on" although this shouldn't be a problem on a race bike and all of the gas has to pass through the filter.
My 2012 300 will be here soon and I will try the 2.9 gallon tank on his bike to check fitment and report back.
