Gasgasogeros
Hi i have read all post about idle adjust i have dj blue needle on 3 from top end pilot 38- 42 main 180 tuning with egt gauge but i don't have idle stable idle , with 38 pilot start easy but its lean end the idle its no stable,
the rpm screw if turn out the idle drop down end after 1 turn out start to going high
with 42 need the air screw to be in all with idle very high if i try to reduce the idle its stable for 1 second and after shutdown .piston new , heed piston clearance 1.2 mm reeds new jacobi its time for ca rb swap with keihin pwk air strike 2 or mikuni tmx
