gg fat bar clamps
I also have a set of risers and fatbars but these bars (new pull off from a ktm) have more pull back than the stock gasser bars. Price $50 shipped (U.S. only)
lanky.......I got a set from an older model Berg with WP forks.....they have 4 pinch bolts...bolted right up with no issues!
I'm really just interested in some spacers that go between the top triple and the bar clamps. My 03 has a 10mm bolt that goes down through the bottom clamp and the top triple with a nut on the bottom. I need two .400" spacers to raise my bars and replace the stack of washers that I'm using with a special shoulder bolt.
Ditch the washers and use an extra set of handlebar clamp tops as spacers in between the bottom half of the handlebar clamp and the top (see photo). Will raise the bars 3/4 of an inch or more. Anyone running the Bonz bark buster mounts should have an extra pair of these clamp tops (which the Bonz replace) lying around. I'm sure I have a set in my spares.
I like the way you think. PM sent
