RockefellerGG
I'm rebuilding my 2005 EC250 and I didn't remember this issue when disassembling. There is a pair of wires coming out of the stator cover, containing a yellow and white wire. I can't find a connection for the white wire. I found this wiring diagram and it looks like it is unused.
Can anyone confirm that this white wire is unused? Perhaps it is for an e-start charging application (which mine is NOT).
Second question: Is the typical ground behind the coil? I see a ring terminal mounted to the coil. I am just trying to determine if I need to clean off the frame paint behind the coil... I can't seem to find another ground. Guessing this was it.
Thanks in advance, guys.
