Hard to start
TRAILBLAZER808
2004 300ec
Is there a shop manual on this bike?
Need to get the voltage output for stator.
Need to get ohm reading for ingition coil.
Spark looks weak.
Any help would be appreciated...
2007 HONDA CRF250X CHRISTINI
2004 GASGAS 300EC
1999 SUZUKI MARAUDER
1998 KAWASAKI KDX 220 (SOLD)
1983 HONDA XR200R (SOLD)
1979 YAMAHA DAYTONA SPECIAL 400 (SOLD)
1976 YAMAHA RD400 (SOLD)
1972 YAMAHA XS400 SPECIAL (SOLD)
I got some voltage readings.
For the impluse coil: Red/White wire - ground = 3VAC at idle
For the impluse coil: Red/Black wire - ground = 12VAC at idle
For the exciter coil: Black/Red wire - Red/White wire = 12.5 ohms
For the ignition coil: White/Blue wire - Green wire = .7 ohms
For the ignition coil: White/Blue wire - spark plug boot = 19k ohms
Can someone verify these readings?
Thank you for your help...
Checked reeds they look good.
Put a new carbureator.
Checked and cleaned all connections.
Compression is 145.
Hooked up a used CDI, same problem.
Waiting for new Ingition coil and rectifer.
I hope thats the problem, a new stator cost $350.00
Why dont GasGas put out a shop manuel like the Japan bikes?
Oh, I guess its so the can sell more parts to bike owners like me, that dont have a GasGas mechanic to go to.
I hate to say it but Japan bikes get so much more support and they dont break down as much.
Sounds like it needs a new top end, compression test should be giving you at least 170psi.
And I've always found mine to be more reliable than jap stuff..:rolleyes:
Thank you for the info.
But you should try to refrain from using RACIAL SLURS. :mad:
Iam sure we have hundreds of members who are of the Japanese Race.
Being a Gold Member like yourself maybe you should place the bar a little higher.
I belive this web site has rules about this....
Its ok to call it a japanese bike but not jap stuff? I don't think there was any underlying (or not) racial slur intended.. But incase anyone was offended please let me know. Until then I appologise on behalf of Todd.
Trail blazer. Its a 10 year old bike. We all agree the Gas Gas workshop manual and supporting documentation isn't as good as you'd get with a Yamaha or Honda. No doubt about that.
Others have given you some advice here and its the same as with any other second hand bike of unknown history. You will need to do some digging.
How many hours on the engine?
How are the reeds?
When was the piston/rings last replaced?
Whats your current jetting specs?
Have you pulled the carb and given it a throrough cleaning?
Have you owned this bike long and was it previously starting easily?
The gas gas engine is as reliable as a stone. They can take a bit of initial setup, but once done very little other than periodic maintenance is required.
When my GG came do for a new slug, she ran pretty good...once running. A major chore to start. As I'm relatively new to 2ts, it took a minute to realize...time for a rebuild.
No racial slur was intended, I apologise if you have taken offence. I was simply being a lazy typer, il be even lazier in future and not type anything.
What are your jetting specs and carb settings? Initial jetting specs are crucial to start any two stroke bike. I personally would drop $20 on brass before I started dropping 10 times that on electrical parts. What electrical issues did you experience to point you to it being an ignition/electrical issue?
Post up your carb specs and jetting and we'll have a look. Did you do a compression test yet?
You can scratch weak spark as an issue since there is no such thing. A spark plug will either spark under compression or it won't....
Whatever you need, someone will sort it out for you.
The jap ignition is very reliable, so probably rule that out.
A couple of roo rooters have jetting recommendations sorted.
The yanks have suspension set ups well tuned.
The northern Canucks are good at bike protection/anti-moose damage devices.
The poms are helpful in local authority avoidance while green lane riding.
The yappies have cooling system issues nailed. It so damn hot!
The euro's won't post in the summer, too busy riding.
I think its compression as well.
