head torque spec
myoung
What is the torque spec for the 6 head bolts on my 08 ec300? I'm assuming incrementally tightening in a star pattern?
Here ya go
Place the cylinder head and tighten the screws in diagonal
pairs. Use thread lock.
Tightening torque: 25 Nm
- Check that the support surface of the thermostat cover is
perfectly clean.
- Fit the thermostat cover with a new gasket and tighten the
screws -1-. Use thread lock.
Tightening torque: 10 Nm
BTW 25nm roughly converts to 18.4 FT/lb
Sorry to be bringing this back up but would these settings be the same as the 2002 ec300? Also is it better to build the o rings for the head in dry or coated with grease or three bond sealer? Thanks.
Cheers couldn't get them to stay in place so used a small amount of stickey grease to keep them in place I ordered the o rings and copper washers direct from gas gas so fingers crossed the problem stops. Thanks.
Another way to keep them in place is to stretch them out for a few minutes, then install the head when they are the "right size." I roll the outer o ring over the outside of the cylinder to stretch it, and I have a coffee can for the inner o ring. Give them a few minutes stretching out, set up all of the bolts, then put it all together in one quick shot before they shrink down.
