Headlight Stop Working
StuJohnson
During my last ride the main (large) bulb stopped working. The tiny marker light stays on at all times.
This is on a 2012 300 Racing - kick start only.
I am scratching me head trying to figure out why it no longer works.
Here is what I have looked into so far:
- I have checked the switch and checks out ok.
- I have checked the bulb and it checks out ok.
- I have chased down the wiring and can't find any fuses.
- I have looked at the electrical drawings from GG and can't find any fuses.
What else should I look for?
Thoughts?
Ideas?
Thanks for your advice and help in advance!!
Take a meter across the bulb and see if the voltage is fluctuating substantially(AC voltage) if it's fluctuating a lot especially on revving the bike it's your voltage reg down on the lower right frame rail by your coil.
Like Trev said, determine if the bulb is blown or the lights just not working. Chase the 12V system around the headlight and work out where you have power and where you don't. I had to do the same a while back (maybe 6 months ago). Turns out a solder join had broke apart. The wiring schematic is very useful too.
