heat cycling
Sorry Doc. Wasn't trying to upset you or anyone else. I think maybe a little was lost in how I worded things. That said, we cool!
No problem SS109, everything's fine ;)
https://www.youtube.com/watch?v=c2eWHNSaSZU pSSST!!! the barra!
What do you think on the matter Doc?
I like to keep things simple..
Buy quality parts, measure tolerances on assembly, throw it together.
Run to test for leaks, etc. Short test ride using some load on acceleration and deceleration to start bedding rings, and then ride it as per normal.
As said its very hard for me to explain complicated things in English. However, some people say they run in their engines other's say that was usually done in stone age and it's not necessary anymore as materials and tolerances are so much better today. Let's leave that open and everyone should decide for himself.
Concerning different materials it is well known that they have different thermal expansion coefficients hence tolerances may vary a tiny bit.
Additionally, and that is not common knowledge many materials come from the manufacturer and their molecular structure is not finally directed (hope thats the word). Hence they have internal stresses that will go away during the first heat cycles. The molecular structure gets its final condition and will remain like this until the end of the life cycle. That especially applies for any casted materials but also to forged pistons and other components.
I am not so sure if I found the right words. Till today I haven't found a good technical dictionary, something that covers especially automotive and scientific phrases and vocabulary...
The piston get quite hot as there is a fire burning above it.
The watercooled parts are quite held around 60 to 70degC in light to mid use, and the rest of the engine doesn't get much hotter. Too hot to hold onto, but not hot enough to burn you.
So how much is this heat treatment happens in ally or steel at 80degC?
The engine, abused in hard enduro gets far hotter than 80 degrees, sometimes over 120.
However, I can't answer your question. Sorry.
i think the real-world benefit of heat cycling is to check that everything has been put together properly to avoid any real damage (so not really heat cycling, but more a careful test run). I have seen national races where they have replaced the engine in the pits and the warmup was from there to the end of the pit lane then full taps and the engine was fine for the remaining 200km desert race
just heating and cooling a piston is not gonna keep you from seizing.
you must have lubrication.
you must have clearance.
run em' tight they stick.....run em dry, they stick. clearance is the thing to watch. most guys grab a piston and shove it in the bore....yep it fits. when you get into bigger bores you need bigger clearances. a little money spent on mics will pay for itself in spades.
The piston changes with use. Run one long enough it wears out, it stresses, it fails. I disagree that once a break in is done, the piston is good to go. Tighter tolerances need a little more mechanical sympathy during break in.
So not the 3-400degC usually used for heat treatment? Must be a special Luke warm treatment process. You then can quench it in liquid of 80degC..
You probably think I'm a dick right now, but sometimes you have to reevaluate Its always been done this way practice and ask Why?
All you say is 100% right and I fully agree with it. But it has nothing to do with heat cycling or the effect that heat has to different materials.
Its not my fault if you don't understand the difference between heat treatment of metals and the effect that heat cycling has to metals that never have been heat treated.
Is that somewhere near the harmonic convergence plateau where the aura aligns?
I don't think anyone here is arguing the point that heat can change the structure of metals. More to the point, what question are you asking?
A forged piston has seen some heat already, both during forging, during, machining, finishing, etc. And will surely see more in use. Is there a specific break in time which leads to optimal structure? At which point does it go beyond optimal and fatigue? How does this matter to us?
I don't care about heat cycling specifically. That happens when I ride. What I care about is a proper warm up, an adequate cooling system with no leaks, no air leaks etc. From there once I've confirmed the engine is sound after any work my focus moves into generating enough load to sufficiently bed the rings in.
How are airplane engines broken in? Some good reading on the matter if you go looking.
I don't think anyone here is arguing the point that heat can change the structure of metals. . . . .
Um, yeah I am. Well, beyond normal thermal expansion, which at the temperature involved is, well normal and happens every time you run the bike
. . . . What I care about is a proper warm up, an adequate cooling system with no leaks, no air leaks etc. From there once I've confirmed the engine is sound after any work my focus moves into generating enough load to sufficiently bed the rings in.
And that must be the most sensible thing anyone has said on this entire thread.
I must have run in 100 racing engines and came to the conclusion that it was easiest on the dyno if the fan could push enough air to keep the normal water temperature. Done with some respect to the ring to bore relationship would result in the same power and engine longevity.
In the old days of air cooling, miserable pistons, 1/2 arsed machining, and hard to mix or crap oil, people would over heat their engines by running them at standstill forever or ragging them before the final piston clearances had been scraped off the interface making them viable as a performance engine.
Copy Roger Dodger!
It was a simple question. Do you heat cycle a new engine and if, how?
seriously,what's hard to understand about it?
Every piston has seen some heat whether forged or casted.
This is what I am trying to find out. Had the chance to talk to a GG factory team mechanic a few years back and the method he described was rather unusual. As they let the engine cool for 24 hours which I have never heard before. So I asked a guy I know from an oil company, he works in R&D and is specialized in tribology and he said that may make sense.
I don't know. I never did any heat cycling. I get a brand new bike and ride it. Done. Which leads back to the question, is anyone doing heat cycles before the bike is just ridden normally? And if the answer is yes, how and why?
I only can say JTD9's from P&W just run on the test stand before delivery. There is no braking in period once the engine is installed. No clue if that is also valid for newer super fan engines aswell, but I'd assume it.
I have always heard that the engines are tested in the factory (probably to pretty high revs) anyway so any heat cycling once it is delivered to the customer is probably already too late isn’t it?
All good.
I think the answer is yes, and probably for everyone. No one builds a fresh engine and smashes it hard on it's initial start up.
There will always be a series of heat cycles prior to really putting a heavy load on it.. I don't particularly call it heat cycling in regards to tempering or changing the structure of metals.
It's more so to ensure the engine is sound.. That there are no unexpected issues (oil leaks, fuel leaks, coolant leaks, air leaks, unexpected noises or behaviour).
From there on in, the heat cycles occur every time it is used.
PS. Even buying a new bike from a dealer the engine will have been started/tested in the factory, again at pre delivery, and most of us will give the bike a start or light ride somewhere before really put it to work. Thus, I'm not really concerned with 'heat cycles'. I care about a sound engine with correct tolerances. I care that the fuelling is correct, and the cooling too. Then I focus on bedding the rings.
All good.
No bad feelings Jakobi, always like your posts and enjoy reading them.
I see it like you, I probably do what everyone does when starting a new engine for the first time. I don't heat cycle it nor do I brake it in. For me the most important is to let it completely warm up under low loads. And I use 40:1 premix the first full tank. But other than that I don't do anything special.
The Sapnish guy said, and here is probably the answer for you swazi_matt, that when they have a brand new engine they treat it very special. I assume its either brand new or overhauled (new piston, rings etc.) and hasn't been started, tested or used before.
I never heard that before on simple engines but I know a lot about how multi cylinder race engines are treated. I know that the legendary Judd V8 is broken in in a very special way as I had the chance to talk the tech chief. Any time before its started oil and water are warmed up or it goes west, but that's another story...
It's kind of the same story though.
All to do with tolerances, operating temps, and thermal expansion. Generally speaking bigger parts require bigger tolerances to allow for greater variations. In a race engine with tighter tolerances you need to remove some of the variables.. thus specific start up/warm up procedures.
From my research, it seems to be the same with most of the 2T reading about heat cycles. Usually bigger bores (think jet skis/snow sleds, etc), moving from a cast piston to a forged. Forged by nature expands more and needs more tolerance. Add to that the bathtub curve and infant mortality, and odds are that when you make significant mechanical changes, that if it's going to fail it's going to do so sooner rather than later. If you're going to have a big piston nip up due to thermal expansion you're best chance of avoiding is a slow warm up, and in the event that it does nip it's best on a low load slow idle than wide open down the track.
Factories probably tend to stick to a certain procedure for consistency and fault finding. The less variables you are dealing with the better.
Yes, that sounds very plausible to me. The BMW engineer (it was a BMW with a Judd V8 engine) I talked too said the engine would be destroyed when its started cold and this is due to the very close tolerances. They had a specially designed external pump with a heater unit connected to the car. One tube was lead through the oil pan to warm up the oil.
Here is a little video of the car
https://www.youtube.com/watch?v=84rE2LcwHIw
Unfortunately Georg, the driver died in a horrible accident at a hillclimb race in 2011. It was a great honor for me to know him.
Here's some food for thought.
Why do we believe that the piston and liner would "wear" to itself in the first hour of operation, but not in the following 100 hours? :eek:
That is the same for F1 cars, they have to be heated up before they start and then they also have a very sophisticated clutch that makes sure that it does not stall as that would also trash the engine (I do not have all the facts, but i saw a tv programme where the presenter took about an hour to get out of the pits because he couldn't get the clutch action right)
