I was thinking close valve rev it till it chokes then open valve a little see if it changes it's tune and I have new nylock nut and washer thanksIt might but you would have to rev the engine and open power valve at same time and not positive if you can time it all correct . But could try or just wait for lever . Don’t forget new lock nut with the teflon and washer . Make sure linkage rod is not in bind when you tighten it all
ill get there ive ordered the part i need but the seller would not let me collect this weekend so i have to wait for EVRI to bring it so maybe a week lolYeah your issue like I said was power valve . And as mentioned some previous owner did something wrong and you now have to figure out what .
