farmerj
OK, I will show my ignorance here.
A guy has a 300 Wild (quad) motor that was run with out oil in the gas, and seized
. He says "The rod broke causing the the piston to fry and damaged the cylinder walls..so it needs a rod, piston, and cylinder." But there could certainly be more wrong than that, couldn't there?
The crank bearings are lubricated by pre-mix, right? The tranny oil only lubricates the transmission in a 2-stroke engine, correct?
This is a counterbalanced engine. Does anyone know what lubricates the counterbalancer?
Trying to decide whether to purchase it cheap and re-build!
Thanks,
Jeff
Thanks,
Jeff
