Hello, how hot can I heat the 2006 engine cases in the oven to install my bearings?
On my first case I did 80 Celcius and bearings in freezer but it did not go smooth. I used the hammer quite a bit, but there is no play luckily.
On the second case, I plan on using a spray to freeze so it gets even cooler. How hot can I heat the case though?
