Hyde front disk guard
Brian VT
This thing is rugged ! It should hold up much better than the c.f. one I had on there. I added a 3rd mounting point (the lower one) and drilled a hole in the bottom to access fork compression adjuster.
I haven't had it out of the shop yet. I'm just getting everything back together from my annual tear down.
The c.f. guard I had covered the same and it didn't cause me any problems in the mud. Maybe the shelf area on this one under the caliper will be a problem ? I'll let you know.
