SingleTrackMind
OK guys, I just cleaned my carb and set the float level because the bike has been sitting for 6 months. I decided to clean the power valve and check the tension. The linkage sticks a little at top end. But I didn't have a gasket set to pull and check it. Long story short, after reassembly the bike starts right up but doesn't idle. The RPMs just go very high and that's it.
I checked the cable and made sure it wasn't out of it's seat or pinched. I was going to check it out again after work tonight but thought I would ask the forum if anybody might have any ideas.
The carb was pissing fuel. So I bent the tab slightly and pulled the jets, cleaned everything and put it back together. if the float level is too high would it have a high idle? Secondly, is it possible to put the PV in 180 degrees off and if I did would that cause my high RPM idle?
