Hi all,
Trying to rebuild my project bike back to factory as the previous owner has made a bit of a mess with it, the electrics in particular.
The ignition coil when I bought the bike was in a vertical position and only attached with one bolt (see attached photo).
Assuming this is incorrect as the top bolt in the photo doesn't connect to the frame, I can't figure out the correct orientation as the tabs on the frame don't line up with the coils mounting points.
Does anyone have any photos to show the correct layout of the coil, regulator and horn please?
Regards
Chris
Regards
Chris
