iancp5
EC300
I wanted to retard my ignition by removing the special washer, using a normal one to retard by about 1mm to fire TDC which is I think in the region of 10 degrees at TDC. There is a marking on the stator which seems to align with TDC. Unfortunately the most I could manage was about 5 degrees due to the fact that the other drillings don't allow the stator plate to move anymore. I couldn't be bothered to unhook the loom and cut the slots in the stator longer at the moment which might be a tricky job.
What I was wondering is why is the stator and case marked for TDC if you can't move the plate that far?
Also it looks like the 3 little bolts position the stator - is that correct?
Because if they don't then lengthening the slots is easy as I don't have to be accurate, I can just drill one end out a bit.
