Jakobi
Well, I finally got it dialed in for the most part. The bike now runs and idles fine, but is still real lean at 0-1/4 throttle. But that is only jetting combination I have found that allows it run well across the range.
I fiddled with everything, so I can't tell you what finally made the difference. Two things that I think are the most likely:
1. When I first got the bike, the airbox was not fully seated on the carb. It was hard to see, because it was on the right side of the bike. Because my problem got worse over time, I think it may have allowed enough dust and debris into the carb that clogged the air screw. While cleaning the carb (twice) I noticed residue in the pilot screw hole.
2. Even after checking my choke cable free play and things looking okay, I noticed the cable can bind at either the handlebar or the carb. I adjusted the routing to keep slack on both ends.
After the main problem was solved I tried all kinds of needle/main/pilot combinations to dial it in and settled on what JD recommends: 180 main/38 pilot/red needle in 4th clip position. My final issue is that lean 0-1/4 throttle. This bike is extremely sensitive to needle taper and clip position. One clip change on the red needle changes a ton, so I think I will keep it on the 4th clip and add a shim under the clip.
What makes you think its lean from 0-1/4 throttle? Are you jetting hesitation? Have you tried dialling it in with the air screw?
