Jetting for 2011 EC250 UK
Quigs
Looking for a starting point for jetting on a 2011 ec250
38mm AS2 carb.
I'm unsure on current jetting specs.
Typical UK weather 6?c to 14?c. 0- 1000ft
Thanks in advance. Looking for needle recommendation. Tight wooded trails with the a few hillclimbs. Thanks
Hi Quigs,
have you had a look at the jetting thread? I am sure you will find useful information there as most members post their personal settings there.
Good Luck
Steve
Hi Steve.
I been having a good look through the jetting threads etc.
Looks like the NEDW suzuki needle could be a good starting point. Also recommended by jakobi.
If you find clip 3 too rich,clip 2 too thin...options...
Necw is same taper,same diam,half clip pos leaner
Necw#3 = Nedw#2.5
Was useful for the 200(Nech #3)but most 250s seem happy with Nedw#2
Necw#3 = Nedw#2.5
In addition to what barossi73 explained...
You might find these tables useful that relate to the Suzuki NE** needles:
Thanks for all the input,
Currently now on.
40 pj
NEDW #3
172 mj
1.5 OUT on the AS
Going to just try raising the needle to #4 so it feels rich then go #3 and #2 Just so I can feel the difference.
Still new to jetting so just want to feel and hear the difference
Went out on bike over the weekend but getting a bit of spluttering when trying to accelerate. Might need to try needle in clip position 2 ??
As per post #9, you may need to be between clip positions 2 and 3 to hit the sweet spot that a lot of people report using NECW @ clip 3.
You can do that by using a fine shim under the needle rather than buying an NECW. I got one from a local model shop that did the trick but it's very fine tuning for a bike engine in typical unpredictable UK weather.
