I'm fiddling with jetting on a brand new 2009 EC300 and would like a bit of a sanity check. The bike came with a 178MJ, 45PJ and N1EF needle. Based on how far out I've been turning the air screw I've been working down PJ size and currently have a 38 in it. I also now have a CCK needle in the bike (and a CCL on the bench).
Here's what I'm observing:
If I roll along in 1st gear just barely off-idle the engine runs smoothly, if I then give it just a tad more throttle I'll get rough and "jittery"; I alternately feel power, then engine breaking. This is slow, like 8-10mph. My assumption is that it's four-stroking? If I then give it just a tad more throttle (we're at about "three tads" of throttle now, heh) it cleans up and runs smoothly again. I've tried the trick of running it on the choke and it's blubbery, so I don't think I'm dealing with a lean condition.
With the 38PJ if I turn the air screw out a ways - like 3-1/2 it reduces that jittery stumble. So, I'm thinking that the PJ is still too large, but that really surprises me, hence I'm hoping for some advice so I'm not running this bike too lean on the bottom. I've moved the needle up and down, but it hasn't made any difference (it also did this with the stock needle). The next size smaller PJ I currently have is 35.
Specs:
178MJ
38PJ
CCK-2
stock slide (#7)
FMF Gnarly/TC2
50:1 premix
50F
400ft
RH 80%
29.80 in Hg
Riding is a mix of tight 2nd gear single track and twisty 3rd gear open trails, so I'm hunting for clean jetting on the bottom. I've looked over other people's jetting and I see (at similar conditions to me) a wide range of PJ's, up to 48! I don't see many 35s.
I haven't really addressed MJ and needle clip yet since this is all under 1/8th throttle.
Thanks
-Jesse
Specs:
178MJ
38PJ
CCK-2
stock slide (#7)
FMF Gnarly/TC2
50:1 premix
50F
400ft
RH 80%
29.80 in Hg
Thanks
-Jesse
