coopernicus
I've been slowly working on swapping suspension from Kawasakis I have with the GGs I have...Does anyone care to know what I find? I am fortunate to have never thrown away much of anything dirt bike related so I have some "real" Ohlins shocks from a 1997 KX on my 2000 300ec and I have a KYB Factory Connection revalved 1999 KX shock that I will try over the winter. The KX and GG shocks have the exact same mounts at the top and bottom only the lengths are different by a small amount. The KX Ohlins is shorter so I bought the different length pull rods to even out the height a little. Overall the KX Ohlins shock works much better than the GG Ohlins but it could be because it is fresh. The KYB shock is closer in length to the GG Ohlins but it is still a little shorter requiring the non-standard pull rods to pull the back end up a little. If I had to guess I would say that it will be about perfect based on how it works on the KX 250 I have. Once I have the shocks figured out I will go to the Forks. I will try the FC revalved KYBs and also a set of Ohlins to see how they compare to the stock WP 43s (okay but harsh) and the Marzocchi Shivers (LTR revalved, I think, and they work fine) on the 2007 GG. I'll post results and info as I get them!
Eric
Eric
