Keihin ASII markings?
byost
I have a 2011 300 Six Days with an ASII carburetor I have gotten the jetting lined out but, I have a quick question. The body of the carb is marked "AL1 0 ALP" the Keihin website says it should be marked "S66" Could this be a GG part number or code?:confused:
Is it a 36/38mm. Where'd you end up? I have seen a similar print on mine. Thought it was around the seam to the float bowl. Never thought anything of it.
Jetting nirvana
Bike year & model = 2011 300 Six Days
Temperature (degF) =60
Elevation (feet) =300-900
Main jet = 178
Pilot jet =38
Needle & notch =CEK 3rd Notch
Air screw setting =1.5
Throttle valve/slide =#7
Results:Clean off of the bottom and pulls smoothly to WOT
Jakobi, Its a 38mm,
