The mod for stream crossings is to root the breather pipes up to the air box whilst leaving the drain/over flow in the original down position. Question out of these 5 pipes is 4 of them a breather & 1 an over flow?
I took the two that come vertical out of the top and ran them up to right behind the radiator fill, but you want the two vertical that come out of the top to be the ones that end up higher up
