well, it could and most probably will rub your frame...and that can't be good now can itThanks guys. I was hoping I wouldn't have to weld it. I'll look for the threads for the relocation. On a different note, the chain roller broke off also, is that a big deal to not have?
http://www.gasgasrider.org/forum/showthread.php?t=14099&highlight=stand
Heres what I found.. I bought the replacement part, but never bothered to install it. Just added a typical TMDesignworks lower chain guide and let it do its thing. Now I just have to find a tree to lean the bike against when I stop.
I wouldn't ride without it. I think it would run the risk of the chain slapping down against the shifter and/or shaft. I rewelded the tab similar to n_green, but instead of installing the kickstand and bracket back between the tab and the frame, I just used a ball bearing roller. I'll take a pic this arv for you.
Sometimes the tab and roller stay with the bracket when it breaks. Othertimes the whole lot goes somewhere in the bush. Either way, fabbing up a new (stronger) tab and then mounting onto that should reduce the likelihood of it breaking again.
This was my fix. Welded a piece of flat stock to a piece of angle iron. The flat stock takes up the space of the broken off piece. The angle iron holds on the inside of the frame. Been working just fine.
Wow, so the part pictured is not welded to the frame?
