Kickstarter Hardware
Brian
Kickstarter fell off yesterday :D. Both bolts were gone...that is what I get for not making sure everything is snugged. I got lucky that I had some extra bolts that worked back at the car. However it looks like I lost the following part "18-KICKSTART PEDAL BASE BALL". Any ideas on how I could find one locally? Would a fastener shop have something like this? There must be some size or #?
The bolts and washers should be easy enough to get.
http://www.gofasters.com/index.php?...83_292&zenid=71fe1161d039936729e10ea2b394fa58
it's a ball bearing - probably 1/4" - could be 3/16 or 5/16 i never checked - you might even have one rolling around on the floor somewhere...
Good point I bet I can find a ball bearing somewhere in the garage that will work. Ya luckily I didn't loose the spring.
Red locktite should be your friend.
Incedently I replaced my old slapper k/s with a yamaha one.What a majic piece of kit,far superiour than the gg article.
7/32 seems to work well. Loctite is on as well. Now I just have to finish prepping the bike for Sunday.
