twowheels
I understand you like the tight steering, but you should have a positive stop. One good hit with the forks against the frame and you'll have dents in the fork uppers. That in turn will mess up the fork internals when passing by that high spot. You could fab one up on the frame like the yamaha one and set your frame clearance to what ever you would like. I did mine at about .100 frame clearance but could be tighter if needed by grinding the stop down some.
Noah's got a good point. I had to replace a set of fork tubes on a Kawasaki KX250 (very similar to the GG in the frame department
