Leonelli AC flasher unit
jakekamo
Im not sure how good some of you guys are with your electronics, but my flasher unit died on me and was wondering if any of you had a circuit diagram of the flasher unit.
if not is it just worth converting it to DC?
any advice would be lovely!
Edit: ac flasher unit from 03 ec250
Thanks!
If you can get the stock AC unit just replace it. A DC powered auto flasher might be trouble, not so much from the flasher itself, but from the fact that you would need to isolate the DC output from the rectifier. Then you have to isolate the grounds from the turn lamps and this will require running some extra wires.
