barkeater
I know there are others with more knowledge than myself. I'm smart enough to know I'm not that smart.
I have attempted to simplify (if that is possible) the relation between EC, XC, MC, SE and FSE for people. Before I post this to the Gas Gas wiki page, I want to run it past all of you first. Let's edit it here before I plaster it on the wiki page.
Edited to reflect changes in thread. 12/22/07
To start, a quick primer on Gas Gas off-road model indicators:
EC – Euducross: 2 stroke enduro motorcycle 125, 200, 250 and 300cc
XC – Cross Country: 2 stroke enduro motorcycle customized for US racing 125, 200, 250 and 300cc
SE – Special Edition: 2 stroke enduro motorcycle, custom built for specific rider requirement in US racing 125, 200, 250 and 300cc
MC or MX – Motocross: 2 stroke motocross motorcycle 125 and 250cc
DE – Dealer Edition: 2 stroke enduro motorcycle customized for the US market 200, 250 and 300cc
FSE or FSR – Four Stroke Engine or Four Stroke Racing: 4 stroke, fuel injected enduro motorcycle 400, 450 and 515cc
Gas Gas started selling bikes in the US when Dale Malasek of Gas Gas USA began importing trials and enduro bikes into the US. Gas Gas parts were handled by Rising Sun Imports.
Prior to this, the brand was only available in Europe.
In 1999, Don Knight at Gas Gas North America (GGNA) took over import and distribution of the enduro bikes (trials line was retained by Gas Gas USA) and building a dealer network from their headquarters in Cleveland, Mississippi. GGNA started customizing the EC model for the US racing market. The EC was built to European Union standards to be street legal in Europe and was loaded with features that were unnecessary for off road racing in the US, like turn signals and switch, speedometer/odometer/clock, mirrors, horn and button, catalytic converter, brake lights and head lights. The EC also had a heavier flywheel for the tighter European riding conditions in the form of a larger output coil for brighter headlight.
The XC was originally based on the 1999 European EC. Stripped down for racing, the XC eliminated the turn signals, horn, speedometer/odometer/clock, and all related wiring and cables. It kept the EC headlight and brake light. It had no handlebar switch for lighting or horn, only a kill button. The headlight toggle switch was located on the back of the headlight assembly. The XC was similar to the Gas Gas MC (motocross), only at the time the MC models had a 4 speed transmission which did not have proper gearing for enduro and hare scrambles racing. MC’s were also not available in the 200 or 300cc displacements. The EC/XC models were available in 125, 200, 250 and 300cc displacements. (Prior to 1999 the MC was known as the MX.)
Gas Gas North America had FMF custom design “Fatty” pipes for the XC, silencer choices included FMF Turbine Core II with USFS spark arrestor or the FMF Power Core, without spark arrestor, as options. The XC also had a higher compression MC head (claimed 14:1 compared to the EC 12:1), smaller flywheel weight for the relatively open terrain in the US and smaller output coil. It also had the same Kokusan CDI ignition as the MC which had a more aggressive timing advance for a quicker hit of power than the EC. The bikes were custom built for GGNA at the Gas Gas factory in Spain in a special manufacturing run each year.
During the same time period, GGNA produced the XCO, which upgraded the EC and XC standard 43mm WP forks to 46mm Ohlins forks. They also produced the SE model, which were custom built XC models. The SE could be ordered with full 46mm Ohlins fork and Ohlins shock, gold anodized D.I.D. Dirt Star U-line rims, Enduro Engineering hand guards, WER steering damper and custom suspension set up specific to the riders specifications.
GGNA imported the XC into the US market along side the EC and MC from 1999 until the factory took over distribution in 2002, transferring exclusive distribution rights in the US to Gas Gas Motors of America (GGMA) half way through the 2002 model year.
When Gas Gas Motors of America took over import and distribution from GGNA in 2002, they eliminated the XC model and began importing only the European spec EC and MC models. The US EC models were not imported with signal lamps or mirrors included. During the transition, some of the EC’s were equipped with FMF “Fatty” pipes and silencers and some with Gas Gas branded pipes and silencers. MC models were equipped with Messico pipes and Gas Gas brand silencers. Dealers were upset with loss of the popular XC and petitioned GGMA for a return of the model. High production costs prevented Gas Gas from building the custom XC models so a compromise was reached when the factory agreed to leave off items from the European EC as it was imported into the US.
The EC “Dealer Edition” was created by Gas Gas Motors of America early in the 2003 model year in response to the elimination of the US exclusive XC models created by Gas Gas North America for NETRA enduro and hare scrambles racing. The DE was created with US dealer input, hence the designation “Dealer Edition” or DE. Dealers had the option to add optional parts and accessories to the model as they, or the customer, desired. The EC “Dealer Edtion” or DE included many of the features of the EC – it had FMF “Fatty” and Turbine Core II exhaust, Michelin S-12 tires, D.I.D. U-line rims, signal lamps or mirrors, choice of 43mm WP or 46mm Ohlins fork, O-ring chain, Ohlins shock, six speed transmission, Chromoly nickel plated frame (until 2004 when they began powdercoating), oversize spokes, hydraulic clutch, and Boyesen reed valves. Beginning in 2004, the WP forks were dropped in favor of forks from Marzocchi and the Ohlins fork option remained as an upgrade.
DE specific changes included: simplified wiring harness without turn signal or horn wiring, two button handlebar switch – headlight and kill button, smaller flywheel and smaller output coil, no speedometer/odometer/clock – the cable was installed however, and MC ignition.
Options for dealers to install included: Dual sport lighting kit, MC front number plate, trial style tail light, taller seat foam, Hebo taper bars, high compression head, 4, 7, 10 or 14 oz flywheel weight, programmable MC ignition for 125, 250 or 300cc.
GGMA imported the DE, MC and FSE from 2003 through 2006 as the primary base motorcycles and the European EC available through special order. The FSE was the fuel injected four stroke model Gas Gas had been developing since 1999. In 2002,2003 they began importing the FSE400 later to become the FSE450. In 2006, the FSE was made available in 2 displacements, the 450 and 515. Both fuel injected and based on the EC models.
In 2006, Barrett Marketing/Dixie Sales took over importing and distribution rights from GGMA. The Gas Gas factory and Dixie sales eliminated the DE model for 2006 importing the only the EC, MC and FSE/FSR models. The FSE was changed to FSR in 2007. Also in 2007, some EC models were equipped with a Sachs shock and some with Ohlins.
Dixie Sales import rights were short lived and ended when the company was purchased by Freeplay early in 2007. Freeplay did not see off-road motorcycles as a fit with their environmentally conscious marketing plan, so the line was dropped. This left Gas Gas without a distribution point in North America. After a scramble to find a distributor capable of servicing the US market, the current Gas Gas trials importer, and original importer, Gas Gas USA of Kansas City, MO was chosen to import and distribute the enduro bikes in the US market. Enduro parts and warranty service was given to GoFasters powersports of Ortonville, MN. Trials parts are still handled by Rising Sun Imports.
At the time this was written, the EC, MC and FSR were the only Gas Gas enduro motorcycle models available in the North American (US/Canada) market for the 2007 and 2008 model year.
