Linkage bearings!!!
GASGASCWB
Hi guys!
The link bearings on the rear suspension of my bike are slack!
Too much slack!
But my bike has only 20 hours...
My mechanic said that this is happening frequently in the European premium bikes like KTM, SHERCO, BETA...
My GASGAS is the only one in the region, so he did not know how to say if this is also recurring in new GASGAS...
In my YAMAHA WR 250 1995 and in my HUSQVARNA 360 2002 I did not even remember that these bearings existed as durable as they were.
Has anyone also had this problem with link bearings so recently?
is it all of them or just the one at the bottom of the shock? This one always goes quickly if you don't grease it regularly.
I assume the newer bikes don't have the o-ring and washer seal setup. that system works awesome, but not sure what effect it plays on the suspension as it is quite sticky
On the bottom!
Grease?
20 hours?
Yes, old suspensons have a o-ring and washer seal...
Actual bikes do not have.
Business...
Grease?
20 hours?
Yes. Many bikes are delivered with almost dry linkage, swingarm and steering bearings. When you buy a new bike, it may be a good idea to take it apart and grease it. Not only Gasgas, but other makes as well.
Mine has 36 hours (EC 300 2019) all linkage bearings and the floaters are gone west. No rust but just defective :mad:
synergy seals used to make teflon bush replacements for the linkage, not sure if they still operate.
have had them in my bike for years now, only the shock bearing that i have to replace (the teflon bush was the wrong size so this one has been normal bearing)
I could get INA or SKF high quality bearings but I can't get the darn bushings. That would mean to buy a GG repair kit plus the high quality bearings. I couldnt find anyone who can offer the bushings alone :mad:
Doc, if you've already done the research - do you have part #s for SKF?
I haven't taken my linkage apart, but it might be worth putting in new bearings before my bushings wear...although isn't bushing wear due to the material in the bushing itself? If so, I might as well run the stock bearings until all need replacement.
Let's put this into a question - will high-quality bearings cause less wear to the bushings than the stock bearings will?
Thanks,
Jeff
Do you guys know where to find the kit for the linkage arm?
I have the kit for the rocker arm but can't find the linkage arm kit.
ROCKERM ARM REPAIR KIT EC 2018 BE32035CT-CLJ-1
LINKAGE ARM REPAIR KIT EC 2018 BE34035CT-CLJ-1
Fits 2018 and 2019 EC 300.
I know AllBalls and ProX do kits as well, but I would doubt if they sell the bushes separately either.
But your favourite GG dealer does! At least my one. Just bought bushes, bearings etc from him. I'm ready for the winter service on my 2015 EC200.
My dealer says the bushes aren't sold separatly for the 2018 and 2019 models. I am looking for bushings since a year now and found no company selling them. I can get the bearings and seals from SKF but not the bushings.
You probably know that if there is a problem its 8 out of 10 times the hardening of the bushings :o
I ordered on motocrosscenter the linkage arm kit i have it for about a week now: https://www.motocrosscenter.com/sho...on-balancin-ec-2018-2018-be34035ct-clj-1.html
This kit is for the arm that connects to the shock(the L shape part), i think its a rocker arm but MC call's it linkage arm and the kit that they call rocker arm i suspect it is for the linkage arm. I Asked for pictures of the contents still waiting on them.
Thanks.
Nate, were did you find those kits? Allballs home page did only show wheel bearings for the Gasser. I'd like to buy a whole kit for the spare parts box but I don't want to buy the ones from GG.
Thanks
Doc
If you are in the states check out rocky mountain atvmc. Swing arm kits are one if like 4 bike specific parts they actually sell for a Gasser
Thanks
Doc
Sorry Doc just seen this, there are a few distributors in Oz. I?ll ask my mate where he got his.
All good Nate ;) I am not Down Under but in Austria. With the part number I found a distributor in Europe. Problem solved. Thanks for your help, most appreciated!
Doc
