Lower Shock Mount
Danj56
Bronze Level Site Supporter
Should there be any side to side play in the lower shock mount after bolting everything together? I have side to side play and don't remember ever having this before. I just got the shock back from service.
Some side to side play is normal. As with any roller type bearing.
The o-rings limit the side play.
Did you install the cupped(?) Washers outside of the o-ring seals? My lower mount is a tight fit
Yes, I put in both washers and Orings, I don't remember it being loose before I had it serviced. I'm going to take it back off and measure the shock width and the suspension parts for clearance something just doesn't seem right.
I also have side to side play. New o-rings and bearing. I dont have the orginial washer thought. 1-2mm play
