My data points with AmsOil...
At 50:1 ratio the top ring end gap increased 0.006" over 91 hours of ride time.
Compression was 195 psi at the start of this period and 198 psi at the end of this period.
At 38:1 ratio the top ring end gap increased 0.001" over 93 hours of ride time.
Compression was 188 psi at the start of this period and 204 psi at the end of this period.
Also note, early during this time period my water pump seal went bad and all the coolant went into the transmission, so the engine also experienced an overheat cycle.
