g'day all, I've just joined the brethren by picking up my very first Gasser, a 2005 model EC200. The previous owner seems to have been a bit lax on the maintenance/tuning side of things so I've been going through the bike and sorting out the little bits and pieces to my liking.
I haven't had much of a ride yet as the throttle cable that was on the bike was about 10mm too long and the adjustment available wasn't enough to take up the slack, I've just fitted a new cable (among other things) so hopefully will get on it in a day or two.
Just a quick question re jetting? The short ride I did have suggested the bottom end was a bit doughy, it has what I'm assuming is a red JD needle in it, clip two notches from the top. The slide is a #5. From what I've read on here these two elements are the main culprits in lack of low-end power, would you change one before the other? I like to change things one at a time (unless it's all blatantly wrong )
Also, to push the friendship, are the oversize powervalve covers worth a look on the 200?
Cheers
Paul
Cheers
Paul
