gasser
If you want to lower it about 1/2 inch you could swap the linkage pull rods for 124s and the extra leverage provided would effectively "soften" your 5.2 spring. I have a pair of 124s if you want to try that route.I just pulled the spring off the shock this morning and checked it in my spring tester. It measured right at 5.2 kg. I also had another spring off an 888 Ohlin, and it is longer than the TTX spring. It won't fit. Dimensionally, the TTX spring has about 63 mm ID and is 245 mm long.
I think I'm going to need a 4.8 or 4.9. Do either of you guys know if your springs will fit?
