Need help please with finding out year of this Engine?
ECgasser125
Any ideas I know its a EC125 but thinking its not the original motor cause title says 05 EC125 but the piston looks like piston for an 03 letter B is also on the head and the piston is 53.96...Did they put wrong piston in it
Specifications call for a 54mm piston. I wouldn't question the "03" marking on the head, I doubt that would signify the year. Maybe the casting lot, but probably not the build date.
Only reason I question the year is because and 05 should have a port on the piston like a square opening and this piston is just solid
If the 125 motor is like the 200,250&300 there should be a tag or stamped series of numbers down by the shifter shaft. The number will break down the year and type.
Wow.. that's hard to believe. I would get it inspected by a good machinist, at the very least, to make sure it's not out of round and of proper diameter.
Theres a bit of the piston melted to the cylinder but im getting it honed and it will be fine. Just took it to machinist today he even said cylinder is fine just gonna clean it up
