Need help with needles.
memphis2857
Currently running a N3CH needle on clip 2. The bike is ever so slightly rich just off idle and then is pretty lean from 1/4 on through until I get on the main. Would a N3CJ help with this?
182 main
40p
0-1000ft
35-85* F
S3 head black insert
Stock Exhaust
182 main
40p
0-1000ft
35-85* F
Stock Exhaust
N3CJ worked really well in my ,13. High comp cut head. Stock and gnarly exhaust. Tons of low end grunt. Smooth, crisp, and strong.
Going half a clip richer on the clip will improve your slightly lean 1/4 throttle up.. This would be an N3E(x)#3
A leaner diameter will help clean up the off idle richness. A W or J. You may need to adjust the pilot to maintain the idle and fine tune of the off idle response.
So a N3EJ or N3EW? Wouldn't the W be 2 steps leaner than the H? Happen to have an OEM part number for them?
Sent from my iPad using Tapatalk
Ok found them myself. 06 yz250 needles.
