gasser
I just put a new 300 top end on my 07ec250 (large ignition). It started right up and seems to run strong off the bottom with a moderate bog around 1/3 throttle. I did a throttle chop and plug check and the new plug was a grey color on the electrode and insulator. I've read that the grey color is a result of pre-ignition and timing needs to be adjusted. I don't have a timing light or anything to measure advance so any tricks or advice would be greatly appreciated.
jetting: 40/175, CCK middle position, oil 43/1, plug B7ES, rain/sun switch in sun position. Temp 69F and sunny, altitude 800ft
P.S.
#1 Piston (Vertex "A") did seem a little tight in the newly replated "A"cylinder
#2 I did set my float a little lower because it had been overflowing when parked on sloping ground. Maybe I set it too low.
P.S.
