Feedback
Went for a quick squirt today on a local testing area. Only a small 35 k loop in an area with more rocks then dirt. Pretty technical area pure 2nd gear maybe 3rd on occasion territory.
First up temp was 20 deg C with humidity at 66%. Riding approx 200m asl.
Started the bike and she was lean, no real surprise having previously set it up at 44 deg C with 20% humidity lol.
Had to go up a pilot size straight away and even then with a 42 pilot the air screw was at 1 turn out. I went up to a 180 main as well to be safe, probably didn't need it, as I said this area isn't a WOT area at all.
The torque off the bottom wasn't affected as much as I thought, a bit more clutch required but it would still pull down quite well in 2nd and even 3rd. I love the mid and top end in this thing now, so fun
Only thing I'm unhappy with was the economy, 5.2L fuel used for 35k's. With that economy I'd be lucky to make it 65k's on a tank!
There were a few lay downs and I dumped a fuel bowl when changing the jets but that wouldn't have used that much fuel.
Dunno, I'll try it again on another normal loop over 60 or 80k's if I make it and see if it was just the technical area making it thirsty.
This is still a massive thorn in my side, why the hell is this bike so thirsty.
