erniebearskin
Hi folks, I am picking up my new EC300 on Friday. Is there any common mechanical issues or minor maintenance items that I should make my dealer aware of to check for before picking up the machine? Thanks.
I'll list the parts that have flatout failed due to the manufacture on my
11' xc 250 Six Day's. You can decide what you want to replace before it potentially happens to you. I'll list them in the order that they happened and what I did to fix the problem.
1- broke footpeg. Replaced with late model Yamaha YZF footpegs.
2- kick starter failed. On the starting of a H/S race. replaced with a kick starter from an 11' yz 250 2t.
3-exhaust pipe split open right up the seam. It was about an 1.5"- 2" open in some spots. This was on the stainless steel pipe that came on the Six Day's model. Of course it happened 2 miles into a race. GasGas warranted it and I got an FMF Gnarly to replace it.
4-The cable choke failed, hung open, also during a race. Someone hit the lever while I was pitted for gas. It took me a minute to figure out what was wrong with the bike. replaced with a std pull choke.
5- Rear brake pedal bushing. Change it before it ruins your rear brake pedal. Checkpoint offroad offers a nice stainless replacement.
The rod from the rear master cylinder also needs to be cut in order to lower the brake pedal height.
Also, safty wire the pin that holds the rear brake pads or just put a 8mm hex head pin in it for a yzf and be done with it.
That's about it as far as parts failing goes. Like others have said watch the spokes, both the front and the rear, for a few rides. They will break in and you will not have to be tighten them as much.
everything mentioned goes for all the gg models - aside from the exhaust issue - haven't seen that one before. pegs, spokes, and rear brake stuff is first thing to fix for sure though. make sure kickstarter bolt(s) are tight.
also, right away remove all the lower triple tree bolts. anti-seize them. then reinstall. it seems the middle one always seizes on all the bikes...
