Simmo737
My bike used to load up after about 20 mins of tree to tree single that was all 1/4 throttle max, with the jd blue clip 2, I went to the nedw ( lean, lean rich) which by inspection is leaner towards the top of the needle ( lower throttle openings) than the jd blue, loading stopped, and that's why I use it for ST ( and its smooth and linear). Jd red would have worked I suspect.
The problem with the nedw for me is when you get in sand, in woops, long fast flowing sand tracks,on a cool day, the bike starts to get a hanging idle and sound lean, dropping to the bottom clip nedw and adding a main jet step doesn't help, so I then use the jd blue. Pain in the butt but safe for the bike.
I'm not sure what the tapers are on an n3, but I would be going on feel and dropping the clip, resetting the airscrew for best throttle response and having a go leaner. My experience is that this bike doesn't colour up the plug real good with newer plugs (and jakobi found the same) unless you do a proper plug chop, but it does colour up the base of the threads and electrode, if you get a nice lacquered dark brown look from the thread base, I reckon your good as long as the electrode hasn't got the crap burnt out of it and there is some colour on the insulator I find the bike starts and idles better with a Br8es, not the br8eg, others have the same experience. Go to the mainjet motorcycles website, they have a lot of good info on jetting and plug chops etc. Watch for the hanging idle, if it happens and wasn't there before, I reckon your too lean.
Moral to the story the bike works well in everything with a leanish setting but your pushing it when you get in sea level sand with l larger throttle opening but not fully on the mainjet.
I find the leaner low throttle opening type of needle , the less burble right of the bat but also the less torque at lower throtle, that low throttle torque is gold on long greasy hills.
Hope that helps
Hope that helps
