Typical gasgas chain slap. Very noticeable at low rpm's when getting on the gas. Tighten it up a little and try it out.
Oh, that's why it sounds from the left hand side and on very low rpm (gears 3-4-5, never heard it in 1 and 2). I've been chasing that rattle for a few rides now.
Thanks for clearing it out
p.s. chain slap looked good when i bought the bike, will have another look at it tonight
Thanks for the video.Here's my old KTM 640 with a very shagged bottom end. It's similar on 2 strokes, a lot deeper rattle than the top end https://youtu.be/Avb-GXMWT6E
Very common in the Gasser's is;
Exhaust rattle - put your foot on the exhaust and rev, does it go away?
Power valve rattle - take the right hand cover off, in the rest position is the cam firmly against the stop?
Clutch rattle - pull the clutch lever in, does it go away?
Engine mounts - are the top mounts intact? They tend to snap, are all mounts tight? If so, remove the nuts and replace the nylock nuts
Clutch hub nut - take the plates out, does the centre nut turn?
I'm 3 lower rollers down so far. The chain slap under "optimal" tension is enough to rip it out. Food for thought, better to run without imho
Engine idle, just changed the jets main and pilot and move the needle to clip#3
What I am interested in; where should it idle? How does the motor sound? Does it have the death rattle?
https://youtu.be/4XVX0b2549k
Yep sounds goooooooood quit worrying go learn how to ride a two stroke you will never go back
I'm a worry wart! Keeps me out of trouble from time to time....I am riding tomorrow with some guys I never met, made sure they understood I'm SLOW....
Bravo, where in E TN are you? If you ride at Moto Mountain or Durhamtown I can meet up with you. Also, you are welcome to bring the bike to my home "shop" and I can go over it with you and address any concerns you may have. I am located NE part of metro ATL about 1.5hrs west of Durhamtown.
