Part-Out 2010 300 and 2009 200
husley
Bronze Level Site Supporter
Part-Out 2010 300 and 2009 200 SOLD
UPDATED 9 18 16
All prices do not include shipping. I think (and hope) that my prices are reasonable. I don't want to make a fortune off this stuff, just a fair deal for both parties......and I want it out of my garage ;)
2009 200 50hrs on the bike. Parting-it-out due to the motor attempting to commit suicide.
Send me a PM or Email (preferably with the part you are interested in and your phone # ) and I'll gladly text pics. Texting is simplest for me.
Engine minus Stator (top end, bottom end, reeds) AS IS Piston and Cylinder damage-not sure what happened. Besides a lack of low-end the bike ran fine, I happened to find the cracked piston when I decided to measure/adjust squish. Engine was actually running fine, have GoPro video of the last ride.. (09' 200)
$400
Pipe OEM. One small dent (09' 200)
$100
P3 Pipe Guard 200/250/300
$75
Oversized PV Cover- this is the one machined by the guy on this forum. It is two separate spacers, uses OEM Cap.
$40
Sachs Shock. (09' 200) Sprung for 200lb rider weight. Valved for rocks/very soft. 09' 200
$150
Triple Clamps. Top Clamp is the GPR Stabilizer Mount Clamp Includes Collar/Pin $150. (09'200)
Triple Clamps OEM (10' 300)
$70
Wheels (front and rear) 09 200. $300. One small dent to rear rim.
Wheels (front and rear) 10' 300 $300
10' Plastics (not including actual/glass headlight). White. Custom Graphics
$50
09' Plastics OEM.
$50
Scorpion Rad Guards (09' 200) $75
OEM Radiators. (09 200')
$150
Plastic Frame Guards (just above pegs) 10' 300 + 09' 200
$5 each
Front Brake complete with lever (09' 200) $150
Aluminum Skid Plate $40 (09' 200)
Rear Brake complete with lever (09' 200) $150
Clutch complete, MC, Slave, Lever and Line
$100 (10'300)
$100 (09' 200)
OEM Tank with Cap and Petcock. (09' 200)
$50
Carb OEM. Jets, Needle, Motion Pro +3" and Throttle included $150 (10' 300)
Carb OEM. Jets, Needle, Cable and Throttle included $140 (09' 200)
Subframe (metal portion only, no plastic/airbox etc) 10 300 $150
Frame with Title $200 (09' 200)
Swingarm- has defect where a bolt that was too long (installed by yours truly) wore into the material. Bearings and Seals are new $50 (10' 300)
Airbox $ 20 (10'300)
Full Linkage $100 (09' 200)
GPR Sub-Mount kit (including collar and post). Stabilizer not included. (10' 300). Also have smaller I.D. Collar. Fits many years
$50
TwinAir Air Filters (2) -used but life left in them $5 each
OEM Chain Guide $5 (09 200')
OEM Bar Mounts $10
Rad/Engine hoses $5
Bucket of Bolts. 75% of the bolts, nuts, fasteners, etc. Basically all the bits left-over after the part-out
$40
Rear Brake Lever (09' 200)
$40
Kickstand
$50
OEM Handguards/Plastic Deflectors (removed at 5hrs) $5 (black, 10' 300)
Wiring Harness with Stator $250 (09' 200)
Sicass Dual-Sport Lighting Kit. Headlight (bulb) included. LED rear turn signals, LED front hand guard turn signals.
$200
New Rear Pads EBC $ 10 ?
Front Brake and Clutch Levers (worked on my 09 and 10)
$15
Let me know what you want for the kick starter for the 200.
Thanks
Rick, the motor might be sold. Let me see what his expectations are for the kick starter. If he doesn't want it, how about $30 + shipping?
J
I will take
OEM Throttle Cable $10
Do you have pegs ?
Ooh, yes. Thanks for the reminder. I have 10' pegs with the bracket cut (to facilitate lowering them) and I have non-altered OEM pegs from the 09' 200.
$30 for either set of pegs
You PayPal friendly? PayPal address: husley7374@aol.com + $10 for shipping 👍
You PayPal friendly? PayPal address: husley7374@aol.com + $10 for shipping ��
$55 coming your way
how about the rubber strap at the back of the tank
I would like this stuff gone. If you are on-the-fence about a part shoot me an offer. I think the folks that I have already conducted transactions with would tell you that I'm a straight shooter. Besides, there is another bike burning-a-hole in my pocket that I want to buy 😝😝
I will take 09 swing arm if you still have it and the map switch and both seats pm me thanks mitch
If you're parting out the engine, I could use the cyl head & power valve assembly from the cyl..
RB
