UPDATED 9 19 16
All prices do not include shipping. I think (and hope) that my prices are reasonable. I don't want to make a fortune off this stuff, just a fair deal for both parties......and I want it out of my garage
2009 200 50hrs on the bike. Parting-it-out due to the motor attempting to commit suicide.
Send me a PM or Email (preferably with the part you are interested in and your phone # ) and I'll gladly text pics. Texting is simplest for me.
Engine minus Stator (top end, bottom end, reeds) AS IS Piston and Cylinder damage-not sure what happened. Besides a lack of low-end the bike ran fine, I happened to find the cracked piston when I decided to measure/adjust squish. Engine was actually running fine, have GoPro video of the last ride.. (09' 200)
$400
Pipe OEM. One small dent (09' 200)
$100
P3 Pipe Guard 200/250/300
$75
Oversized PV Cover- this is the one machined by the guy on this forum. It is two separate spacers, uses OEM Cap.
$40
Sachs Shock. (09' 200) Sprung for 200lb rider weight. Valved for rocks/very soft. 09' 200
$150
Triple Clamps. Top Clamp is the GPR Stabilizer Mount Clamp Includes Collar/Pin $150. (09'200)
Triple Clamps OEM (10' 300)
$70
Wheels (front and rear) 09 200. $300. One small dent to rear rim.
Wheels (front and rear) 10' 300 $300
09' Plastics OEM.
$50
Scorpion Rad Guards (09' 200) $75
OEM Radiators. (09 200')
$150
Plastic Frame Guards (just above pegs) 10' 300 + 09' 200
$5 each
Front Brake complete with lever (09' 200) $150
Aluminum Skid Plate $40 (09' 200)
Rear Brake complete with lever (09' 200) $150
Clutch complete, MC, Slave, Lever and Line
$100 (10'300)
$100 (09' 200)
OEM Tank with Cap and Petcock. (09' 200)
$50
Carb OEM. Jets, Needle, Motion Pro +3" and Throttle included $150 (10' 300)
Carb OEM. Jets, Needle, Cable and Throttle included $140 (09' 200)
Subframe (metal portion only, no plastic/airbox etc) 10 300 $150
Frame with Title $200 (09' 200)
Swingarm- has defect where a bolt that was too long (installed by yours truly) wore into the material. Bearings and Seals are new $50 (10' 300)
Airbox $ 20 (10'300)
Full Linkage $100 (09' 200)
GPR Sub-Mount kit (including collar and post). Stabilizer not included. (10' 300). Also have smaller I.D. Collar. Fits many years
$50
TwinAir Air Filters (2) -used but life left in them $5 each
OEM Chain Guide $5 (09 200')
OEM Bar Mounts $10
Rad/Engine hoses $5
Bucket of Bolts. 75% of the bolts, nuts, fasteners, etc. Basically all the bits left-over after the part-out
$40
Rear Brake Lever (09' 200)
$40
Kickstand
$50
OEM Handguards/Plastic Deflectors (removed at 5hrs) $5 (black, 10' 300)
Wiring Harness with Stator $250 (09' 200)
Sicass Dual-Sport Lighting Kit. Headlight (bulb) included. LED rear turn signals, LED front hand guard turn signals.
$200
New Rear Pads EBC $ 10 ?
Front Brake and Clutch Levers (worked on my 09 and 10)
$15
Added to the list 9/20
OEM Louevers (spelling?) One set white, one black.
$5 each set
