It has nothing directly to do with base valve compression valving. I agree with Steve that the PFP preload will affect the overall force at which the fork starts to move, while the PFP spring rate itself will be additive to the main spring rate throught the range.
Its all about reducing cavitation on the midvalve side of the rebound piston. The stiffer the midvalve, the greater the pressure drop or differential and the lower absolute pressure. Bubbles form when this pressure drops below the vapor pressure of the fluid. If the total cartridge pressure is kept high, the differential across the midvalve will not drop the pressure low enough to cause this cavitation effect.
Just like a shock, but shocks have been pressurized for a long time as the single piston design with high differentials requires it.
