Finally got out for my second real ride. Only 70 miles, but didn't get started til late in the day. Rode until it was dark and I'm very pleased with how the LED lights illuminate the trail. Mostly single track riding; engine temperature averaging 135*F. Showed 125*F when running on forest roads, 155*F a few times when bushwacking around deadfall.
Originally, the stock jetting was rich so I switched to a JD kit. JD's recommendation is 38/1.5T/Red#4/170. Presently I have 40/1.5T/Red#4,175. I found it hard to get a stable idle, so I set the slide stop for a fast idle. It will do for now. I went rich on the main as I prefer the power to be flat on top.
The engine was pretty oiled up (from the original jetting) and I had to warm the bike up completely before it would take throttle. At first I got some "knacking" from the pipe, but after a run on a forest road, this went away. Throttle response in the single track is OK. My riding is mostly 2nd gear with 1st or 3rd as the trail varies. The other riding is dirt forest roads to connect trails. This is mostly 6th gear riding.
What I am concerned about is the "pinging" sound I was hearing when in 5th and 6th gear. It didn't seem to change based on the amount of throttle. It was most noticeable crusing at 1/3 - 1/2 throttle in 6th. Is this possibly chain noise resonating in the swingarm? I don't think the jetting is excessively lean, but I don't have enough time on the bike to know what it should sound like.
I took a photo of the plug. The insulator was a bit whiter than I expected, but not a real bleached white. This was after a 5th or 6th gear run back to the parking lot with only a few seconds of idle before shutdown. Any advice?
