Please Confirm
coachtech
What model 2011 came with 48mm Forks? Looks like the lower clamp is $260. The lower clamp area on the WP fork is 60mm. Is the 48mm zoke and sachs also 60mm in this area? If so, looks like an oem lower clamp is the way to go.
thanks
jz
Early 2011 models running the left over Sachs forks were 48mm. I think they had Sachs front and back in the states. Then the later model 2011 EC250/300 R models, the cervantes and the nambo all had the CC 48mm zokes. The stock models and the six days had the Ohlins 888/Zoke 45mm combo.
Haven't measured my lower clap to confirm the size but I'm sure someone here has and will chime in.
