After 100hrs of flawless running my 2006 300 did an odd thing. While running the road at a good clip the exhaust note suddenly changed and the next thing you know the engine is locked up and the back wheel is skidding. In with the clutch and pulled over expecting it had seized, but found neutral and it kicked over fine with normal compression, but when it started it was rattling like a SOB. Sounded like a piece of metal rattling inside the expansion chamber. DNF for the first time.
During the teardown I'm expecting to find a broken clutch tab, piece missing from the piston, or something obvious.... nothing. In fact, the clutch, cylinder and piston all looked in great shape for approx 100hrs use.
What I did find was something possibly odd with the power valve. When you hold the flapper stationary, you can grab the lever plate (the part that the actuator rod attaches to) and move it about 15-20degrees without too much effort. Should this not be one rigid piece ???
I would think thats whats causing the rattle, but I still don't see any indication of where anything hit together to cause it to lock up. (no marks on the piston or flapper)
I'm trying to remove the whole pv assembly now and I've pushed out the one rod that is under the allan bolts that hold down the bearings, but I can't pull out the stupid pv assembly on the right side. Any tricks to get it out ? or any idea what could have happened ?
