SingleTrackMind
Just curious if I could have put the PV in 180 degrees out somehow? I pulled the right side, behind the pipe. When I reinstalled it over the pin inside the head and everything appeared to line up without issue, linkage went on fine, etc.
However, now when I start the engine the RPMs jump to WFO pretty much. Like the throttle cable was stuck on something but its not. Kill switch didn't work, key didn't work, even pulling the spark plug didn't shut off the motor. I blipped the throttle and it finally died after about 30 seconds of panic.
Anybody have any ideas for me? I'm getting ready to pull the carb just to do an inspection and see if something is up. This is a first. I'm completely baffled.
